Report note location of a balloon note referenced from the Location Grid in Creo drawings.
I need to report location of a balloon note referenced from the Location Grid in Creo drawings.
it worked for me when reported a view location like this &pos_loc:view:<view_name>
when using the same for a balloon note &pos_loc:draft:<balloon_note>, it doesn't work.
Any ideas?
Emeritus
Hello ELDAFRAWY
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process. Also please clarity which version/date-code of Creo are you using?
Vivek N
ELDAFRAWY12-AmethystAuthor
Hello Vivek N,
Thank you for your response and valuable advice. I appreciate your recommendation to provide more details and context in my initial inquiry.
Regarding the suggestion to include screenshots, I understand the limitations for this particular issue, and I apologize for any confusion.
As you asked, I am using Creo 4.0 M150 for this project.
Once again, thank you for your support.
Mahmoud
