restricted parameters can't read symbols from tekst file (µ)
  • July 25, 2022
  • 6 replies
  • 1926 views
I am using Creo Parametric - Release 7.0 (connected) Release 7.0 and Datecode7.0.2.0
im new at this so maby this is not the correct place to ask, but is sure looks the best
when making a restricted parameter with a text document i use µ in one of the options, but in creo when selecting the option it shows "µ" instead of "µ".
i tried some other sybols and it does the same thing with the Â
annyone know whats going on?
Best answer by WD_9815979
it is indeed a problem with the UTF-8 that should be UTF-8-BOM
https://www.ptc.com/en/support/article/cs288478
so i did save as, and at the bottom you can change the UTF-8 to UTF-8-BOM.
after updating the restriction definition it works
I'm not sure if Unicode is supported in restricted parameter files.  Is the text file encoded as UTF-8?
i dont know what unicode is or how to tell if it is encoded as UTF-8. but its a .lst file it thats what the question is
I'm seeing the same thing.  You probably should open a support case and see what tech support has to say about it.
im going to do that. thanks
