Retract offset (retract plane height) in a repeat region table
  • January 6, 2017
  • 0 replies
  • 855 views
I need to display the value of the retract offset (retract plane height) of the NC sequence, in a repeat region table.
This value may be visible in Process manager via Mfg Setup Items named Retract Offset. The same value can be generated into the CL data through PPRINT parameter RETRACT_HEIGHT.
Unfortunately I am not able to display this value in a repeat region table.
Does anyone of you have knowledge how to solve this problem?
Rostislav
