Revising Drawing sizes
I have a situation where i need to lengthen a roll-sized drawing. This is something that I have done at another company, so I know that it can be done. I don't know if it's because I'm on Wildfire 4.0 now, but I cannot find a way to increase the drawing size (length). I don't have to create a neew format for the new size, do I?
Can anyone give any suggestions?
File>Sheet Setup... (Page Setup in WF4 and earlier)
Select Variable Size under Format
Enter desired Width and Height dimensions
I forgot to add that this WILL remove the format you currently have. It only increases sheet size, if you need the format I believe a new one will need to be created.
