Revolving is not round it is coming hex
Hiii Good Morning all,
I have just started to learn Creo, I have installed Creo 10,
while revolving i am getting issue, instead of round it is coming hex revolving,
KenFarley
KenFarleyAnswer
Perhaps you are experiencing the same as the person in this discussion:
https://community.ptc.com/t5/3D-Part-Assembly-Design/Revolve-result-is-not-smooth/m-p/906754
Michael
Check chord height to control curved surface resolution high values make circles look like polygons change it in file > options > model display find chord hieght and lower it. Also facet surface display creo settings affect facetted surfaces low resolution can make curves look like polygons adjust in model display options.
Michael Bourque
KenFarley
KenFarley21-Topaz IIAnswer
