Ribbon cable modeling
Hello, everyone:
I am trying to model a coloured ribbon cable 24AWG (8 conductors), and my question is: can I modify the pitch between conductors? Right now i have .2 mm between conductors centerlines... but my connector has 2.54 mm pitch. So i would need my ribbon cable to be the same 2.54 mm pitch. Can I do this in CREO? I would appreciate your support.
    Hope this helps
    Article - CS66721
    Ribbon cable width cannot be changed in Creo Parametric
    Modified: 24-Aug-2020
    Applies To
    • Creo Parametric 1.0 F000 to 7.0.1.0
    Description
    • Ribbon cables with distance in between the cable conductors cannot be created such like
    O-O-O-O-O-O     instead of     OOOOOO
    • Ribbon spool parameter WIDTH does not work
    • Ribbon cable width cannot be changed
    Resolution
