Righ Click No Dropdown Menu
Hey guys,
Just start learning Creo. I now have a problem:
In the instruction, instructor does a lot of right-click, will have a pop-up menu, as shown below.
Mine will not show anything. Is there some setting?
How do I change my software? Or how can I define the angle between two lines? Thanks!
Remember to slam down the right mouse button at least for one second. There is a delay in the right-click menu. It does not come up as quickly as in any other Windows program.
StephenW
It depends on which tab you have selected and if you have pre-selected any geometry or datums.
RMB is context sensitive so you will get different options based on what you have selected or not selected.
So its a right hold more than it is a right click 😵 I wish I knew this a few months ago
kdirth
RMB has two main functions depending on how long you hold it.  A hold (~1/2 sec) will bring up a context sensitive menu, A click will perform a querry selection: cycles the preselection through all of the items available for selection under the pointer.
