Jul 21, 2019 7:01 PM UTC
Rigid vs. Weld connection
In this tutorial, you can learn the differences between Rigid connection and Weld connection.
Note: Adding a rigid connection to a second component of the sub-assembly has eliminated the motion - these surfaces cannot be coincident. To assemble this sub-assembly and maintain its motion - the Weld connection set should be used.
