Feb 13, 2026 2:58 PM UTC
Rule Based Simplified Representations
I have an assembly with two components. Every components has a simplified rep with the same name; UDSR where one feature is excluded. When I create a simplified rep in my assembly, I can select the User Defined Simplified Rep, pick UDSR,  from each component. Works perfect. Now I want to create a rule-based simrep, where every component is loaded with the user defined simrep "udsr" in it.
In the rule editor, I am on the Status Tab, selecting Display. Is it possible to search for a user defined simrep with a particular name?
Creo74Answer
Feb 20, 2026 7:10 AM UTC
Hi All, I further deepdived into the knowledgebase showed me this:
Article - CS384183 - To create a Simplified Representation by Rule that will evaluate all parts tha…
Many thanks for your reaction. Topic can be closed.
Ruben
Chris3
Feb 13, 2026 3:43 PM UTC
When you go into the rule editor, User Defined is not one of the options. I am not sure what option you picked but I don't think this is possible.
Rule Editor:
Manual Definition:
Creo7412-AmethystAuthorAnswer
Ruben
Emeritus
Feb 20, 2026 4:51 AM UTC
Hello @Rubio74,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
