Jul 28, 2016 2:10 PM UTC
Running Simulation on a assembly with complex geometry
How do you deal with situation when some of the components (cast) doesn't get meshed. When I run the AutoGem, it shows few surface which is causing issue. If I need to fix the model, its going to be lot of time and no guarantee that creo with generate mesh again.
Model is cast part created using surface and then solid volume.
Any suggestions?
Chris3
Jul 28, 2016 4:40 PM UTC
Try meshing the part by itself.
Try exporting the part and then re-importing it.
Check your accuracy.
dbhaskara1-VisitorAuthor
Jul 28, 2016 4:42 PM UTC
Which format to export ? I tried STL
2-Explorer
Jul 29, 2016 4:23 PM UTC
In addition to what Chris suggested, try setting the default contact setup to free and see if the assembly meshes. This helps determine if the issue is with the mesher trying to get a contiguous mesh at the interfaces.
