Sep 14, 2022 4:54 PM UTC
Running simulation with higher cores
How to run simulation using higher number of cores?
Sep 14, 2022 5:43 PM UTC
I fear that you are not in the correct community. Here you are in the community "Creo Elements Direct" that is a software different from Creo Parametric. You should move your post to the community "Creo Parametric" to have a better chance to get an answer.
Sep 15, 2022 6:39 PM UTC
Thankyou! I'll post in the parametrics community
