Same parameters on all sheets
How are people using the same data sheet to sheet?
And what I mean is, on my projects I use ~20 sheets on project (all in one DRW). It's a main assembly, some sub assemblies and all the components.
So to be most efficient, I only want to type in say, the project number once and have it on all sheets I create.
I assume most people put their parameters in their models. And that's fine, is that the only way? If I put the parameter in the main assembly will it carry over to all the other sheets in the DRW? I haven;t tried it, but maybe that's the answer.
thanks!
Matt
