Jul 24, 2022 8:44 AM UTC
Same scale for different Reps
I need to have two different Reps in the same sheet of a drawing.
I start with the Master Rep and a certain scale of the drawing; when I change Rep and I choose other one the scale of the new one is different from the first Master Rep.
I want the same scale. Is there an option or some other thing that can set the scale automatically?
KenFarley
Jul 24, 2022 3:32 PM UTC
I've never seen such an option before, I wish there was one.
The scale is calculated by the program somehow and it re-calculates it (usually wrong) every time a new model is added and views are created with the new model.
It's particularly annoying when a change of scale is desired. You have to make the change to the currently active model, then activate every model used for views on the sheet and change their scale, too.
I've use Drawing relations in the past to try to link all the scales. Equations with something like "scale:13 = scale:5" but it's not convenient. I wish there were a parameter that would make the default the last scale used, but as far as I know, there isn't.
Jul 25, 2022 3:43 PM UTC
I've posted an Idea....
so...we wait...
