Save as PDF - specify location
  • December 16, 2011
  • 3 replies
  • 849 views
Typically I plot to postscript and use a script in the plotting to convert it to a PDF using ghostscript.
The problem is I have that configured to do black and white only.
I have a case where we have some draft features on a drawing that have a hatch fill with various colors.
I can use save as pdf to generate a color pdf. No problems there, but the file ends up in the working directory not the plot files directory.
Anyone know how to specify the directory the file is placed in when it makes it?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
Have you tried to set working directory to the plot directory?
20-Turquoise
December 16, 2011
You could  create another .pcf and specify the plotter = colorpostsc.
> David Haigh
> Phone: 925-424-3931
> Fax: 925-423-7496
> Livermore, CA 94550
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
plot_file_dir in your .pcf file
Best Regards,
Patrick Asselman
