Screenshots inside Creo
Greetings all.
Does anybody know if there is a way to take a screenshot inside of Creo within a window? I currently use the printscreen button and paste it into Paint. I then select the area I want and put that in an email. I am looking for a way to select a window in Creo and paste that into an email without having to use Paint.
Thank you in advance for your assistance.
InoramAnswer
I use snipping tool. In fact, I keep on the taskbar cause I use it multiple times daily.
The downfall of it is the quality drops a little.
StephenW
I use Snag-it here at work. It allows you to window select and area.
I think with windows 7 and up, Snipping tool is an option. Go to the start menu and then in the search box start typing snip and it show up. It will allow you to window select a specific area to copy
Inoram14-AlexandriteAnswer
I was unaware that a snipping tool existed in Windows 7 until you and another member suggested it. I did look into it and it will accomplish what I wish to do.
Thank you all for your responses.
In Creo Illustrate you can copy screen so you can paste it in some paint prog. They could put this in Creo Parametric now that graphics are amped.
thanks you this solution can print 600 dpi picture
7-Bedrock
It is also possible to position the model to your needs, and then click File > Save as > Save a copy > .jpg.
set what settings you like and click OK.
you now have at better screenshot then the snippingtool.
