Select all "small" parts/components in assembly
Hello all,
I want made Shrinkwrap from big assembly. But in assembly is many small parts (components) and Shrinkwrap creation failed.
Is thare any filter to select all small parts depended by their volume or area?
Thanks a lot.
try using Find tool.
In my case I wanted to find models with volume < 1000 mm3
minco4-ParticipantAuthor
Thanks, this is what I mean!
HamsterNL
18-Opal
October 24, 2019
If you want to exclude those small components (parts) from your shrinkwrap, you could create a Simplified Rep and exclude components based upon their size.
You will have to create a Rule Based simplified rep:
https://support.ptc.com/help/creo/creo_pma/r6.0/usascii/#page/assembly%2Fasm%2Fasm_two_sub%2FTo_Create_Simpli_Represens_Using_Defin.html%23
https://learningconnector.ptc.com/content/tut-3268/rule-based-simplified-representations
