9-Granite
Set coordinate system at very long distance
Hi all,
For the need of exporting a BIM model (using BIMDeX ifc exporter), I must set an export coordinate system located at a very long distance from the local coordinate system of the project.
This export coordinate system is located round 2000 km in X and Y axis (don't ask me why !) and Creo 7 doesn't accept such length. The project is about 150 meters long with parts of some millimeters dimensions.
Is there a solution to deal with such length into Creo 7?
Thanks for any help.
best regards.
@Steelfoot wrote:
Hi all,
best regards.
contact PTC Support and ask them to reveal hidden config.pro option which enables to enter values higher than 1.000.000.
KenFarley
I don't know what the defaults are for Creo 7, but maybe the accuracy setting is causing trouble? In Creo 4, the default is "relative", which often causes troubles when there is a combination of large and very small features, etc. I don't know what effect changing to "absolute" will have on you if you're trying to deal with such an enormous difference in "sizes". We often have to deal with working on small parts that are located with respect to aircraft coordinates. The coordinate system for the aircraft can often be very far away from our parts, but not anything even approaching the geographical (or perhaps astronomical?) distances you are talking about.
@Steelfoot wrote:
Hi all,
best regards.
Steelfoot9-GraniteAuthor
9-Granite
Hi Ken and Martin,
Thank you for your responses.
Martin, this problem learned me that Creo does not accept numbers greater than 1.000.000.
Both of your answers gave me the idea of changing the unit system of my assembly, from millimeters to kilometers, so that the coordinates I have to set become smallest than 1.000.000.
Changing to kilometers unit cause visual problems on the assembly. I suppose this is due to the way I reach the decimal accuracy.
I'll make another try today with both of your remarks. Otherwise, I will look at a BIM software to make a coordinate system translation after export.
Best regards.
Steelfoot.
@Steelfoot wrote:
Hi Ken and Martin,
Best regards.
Steelfoot.
I would like to repeat my last reply ... contact PTC Support and ask them to reveal hidden config.pro option which enables you to enter values higher than 1.000.000.
PTC Support web page ... https://www.ptc.com/en/support/
On this page there is OPEN A SUPPORT CASE link. Using this link you can open support request.
