Set up .dtl file for each sheet of drawing
Hi, For detailing, we use to set overall .dtl setup only for whole file. In that case can we change or set that .dtl. file for each sheet separately to control the parameters in each sheets? For ex:. For sheet1 -setup 1.dtl, For sheet2-setup2.dtl.
--Mani
requested functionality is not available. DTL options are applied to all drawing sheets.
All right fine. Is there any option to control the parameters from different sheets as my requirements by any manual methods?
Thank you
Thank you
your question is too general.
