Sep 29, 2022 2:49 PM UTC
shape tolerance first zero before dot missing
when I create a shape tolerance it looks like that:
But actually I want it to be 0.02 instead of .02.
Did not find a way to fix that.
Does somebody know?
Greetings
Spedex
StephenW
StephenWAnswer
Sep 29, 2022 2:57 PM UTC
There are drawing setup options you'll need to review
gtol_lead_trail_zeros
lead_trail_zeros
dim_tol_lead_trail_zeros
lead_trail_zeros_scope
StephenW
StephenW23-Emerald IIIAnswer
lead_trail_zeros
Spedex12-AmethystAuthor
Sep 29, 2022 3:18 PM UTC
Changed the second option (lead_trail_zero) to metric, worked.
Thank you.
tbraxton
Sep 29, 2022 3:00 PM UTC
What drafting/drawing standard applies? That will govern the use of leading zero on drawings and MBD annotations? ISO vs ANSI drawing setup will affect how this is displayed.
You can override with config options as presented by @StephenW .
Sep 29, 2022 3:11 PM UTC
Besides the options mentioned by Steve, your part dimensioning units will play into leading vs trailing zeros being displayed according to your chosen standards.
