Sheet metal: bend radius in drawing. Double dims.
Hello, everyone.
This is the topic: I have sheet metal parts that can be created in mm or inches.
For drawings, we have double dimensions: mm and in. I would like to have a table showing:
Column_1                   Column_2
Bend radius:              xx.x mm (yy.y in)
Material thickness:     xx.x mm (yy.y in)
Where: xx.x and yy.y are called by parameters. yy.y would only be xx.x times 25.4 (or viceversa).
To take in consideration:
  1. I have a parameter that is unit sensitive already set up called "Conversion", which tells me the length units: mm or in, under the column "Unit".
  2. Those can be 2 different tables: one table for parts/drawings in "mm", and for parts/drawings in "in".
Then:
  1. How to setup a relation that makes the conversion between them depending on the units?
    1. As I know it's possible to set up relations using "if" and "else".
  2. Considering that for repeat regions it's possible to set up a parameter unit sensitive and call for its units using &asm.mbr.ptc_unit.'my_parameter', is this something I can reuse?
Help is very appreciated.
