Show center line as dashed line in pdf drawing
  • October 3, 2016
  • 8 replies
  • 5471 views
Hello all,
I have put up hole centerline in creo drawing. but when I take its print as pdf. the dashed lines are shown as solid line in pdf drawing. Please let me know to show them as dashed line same as displayed in creo .drw ?
probably the problematic hole has small diameter. Just for testing purposes, please create "bigger" hole and generate PDF.
MH
hvyas1-VisitorAuthor
Nope. I tried but its having the same result.
2-Explorer
October 3, 2016
PTC's output to PDF is flawed and doesn't duplicate what is seen on the screen.
If you can stand to, Printing to PostScript, using USE_SOFTWARE_LINEFONTS and INTF2D_OUT_STROKE_TEXT. The resulting *.ps file can be converted to a PDF with Adobe Acrobat Distiller, or GhostScript or any of several other distillers.
It will not have searchable text as PTC does not include the searchable text (I presume these require pdfmark entries to do so.)
How to save .drw as *.ps file ?
in CR2 you can see following dialog box.
MH
