Show Layertable and selection-check-boxes importing DXF/DWG-Files
reasonable for Drafting / Annotation and Workplane in Modeling
It would be very helpful to get a list of all layers contained in a DXF/DWG-File before importing it, so it to be able to select only the needed ones.
At the moment only Drafting gives the possibility to select geo with layer-selection, and this is not really practable.
Also it would be helpful to get an option-menu in the load-dialog like STEP, IGES, etc to define the wanted import-parameters, such as font-Handling, multi-sheet, hatch-behavior. A normal user is not able to make changes on the DXFDWG.con, (WIN7 Policy is blocking it)
We need the layer-functionality to import DXF-Data out of "Mentor Expedition" to visualize the cooper-areas and impress it to the pcb. Necessary to check distances to housing etc.
