6-Contributor
Show parent at top of flat repeat region (drawing bom table)
Can I configure a Drawing repeat region (bom table) that shows parent assembly on first line followed by only first bom level components?  Recursive table shows parent at top but shows all bom levels.  Flat table shows first level bom only but does not show parent at top.  I am using Creo 9.0.2.0
set Recursive option and add following Filter
&rpt.level <= 2
&rpt.level <= 2
wcash6-ContributorAuthor
6-Contributor
Works perfectly.  Thank you Martin.
