Aug 17, 2020 10:33 PM UTC
Showing Annotations in Assembly Drawing
In CREO 5;
How do you show annotations (e.g. axes) by drawing view for one component in an assembly?  There is a right-click option in the model tree to show dimensions by drawing view, but not annotations.  Thanks.
Aug 18, 2020 8:07 AM UTC
@wbottis wrote:
In CREO 5;
  • open drawing
  • under drawing tree you can see model tree
  • in model tree select component
  • click RMB and select Show Model Annotations command
  • in Show Model Annotations dialog box select the last tab
  • select axis to show
wbottis14-AlexandriteAuthor
Aug 18, 2020 11:53 AM UTC
This shows axes in all drawing views, not just the desired drawing view.
Aug 18, 2020 12:01 PM UTC
I tested your problem in CR5.0.5.0. I am able to display axis in single view.
Aug 18, 2020 1:04 PM UTC
I recommend setting the following config option. It makes showing annotations a lot easier. You don't have to select a component to show annotations. You can select the assembly and choose what to show for the components. Video attached.
show_axes_by_view_scope all_sub_models
Ty
