Shrinkwrap missing merged solid option
Hey there! When I am trying to merge two parts together using the creation method of "merged solid" using shrinkwrap, it seems to be missing. There are only two options; surface subset and faceted solids. Wondering how to get it back as an option?
Are you trying to shrinkwrap a part or an assembly? I only have the merged solid option available when trying to shrinkwrap an assembly.
  • Open assembly
  • File > Save As > Save A Copy > Shrinkwrap
  • Merged Solid
Creo 4.0 M120
If you're doing a shrinkwrap feature: Set "Autocollect all solid surfaces", then in the Options tab, check the box "Solidify resulting geometry". Can't do it if you have it set as "Outer shell".
