Jul 18, 2012 1:32 PM UTC
Simple Animations in Creo? PTC, are you listening.....
When are we going to get the ability to create Simple Animations in the core license of Creo? Are we ever?
SolidWorks allows you to freely move your components in an assembly to simulate how it will operate in motion. It also allows you to easily create animations that can be exported out in a movie file. Why is it that PTC has failed to recognize the advantage of this and does not have something similar to offer us.
In a Creo Assembly, you can't drag your components around and see how things work. You must have Mechanisim extension installed. This is also true for making simple animations.
Does anyone else here know if a TC group is discussing this with PTC. Something so fundamental is missing and their main competitor has offered it for many years.
On that note. Does anyone have any recommendations for creating animations of Creo assemblies by using other software such as Blender? I want to experiement with this but if someone has already documented the process, I would love to know about it.
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
Chris3
Jul 19, 2012 4:30 PM UTC
FYI for those that have it ProductView can create animations as well and for some things it is easier.
Chris
This communication, including any attachments, consists of non-public information that is intended solely for use of the individual or entity to which it is addressed. It is a confidential communication that may contain information that is proprietary, privileged, export-controlled and/or exempt from disclosure under applicable U.S. and non-U.S. law. If the reader is not the intended recipient, or agent responsible for delivering the message to the intended recipient, please notify the sender immediately by reply e-mail and delete the communication, including any attachments, from your system without saving any information or making any physical copies. Unauthorized use, dissemination, distribution or copying of this communication, including any attachments, is strictly prohibited.
Jul 19, 2012 9:09 PM UTC
After playing with Animations for at least 6+ hours, I can finally say this....
IT'S HORRIBLE.
This has to be the worst implementation of Animation software I have ever seen in my life. I have created Animations is several other applications and it's FAR easier than what PTC offers. I was able to figure out how to Animate something in Maya easier than Creo.
I created an animation with two tracks and if I animate each individually, it works fine. When I animate them together the animation breaks the part apart. I have components flying in directions that are not part of any Snapshot. This is terrible.
Adding keyframes is so confusing because I can't rename them individually for each track. At least I can't figure out how to name them and this says a lot for user friendliness.
PTC, This is a JOKE. You need to redo the entire Animation UI and features in Creo or you will never meet your goal of being the most user friendly CAD system.
I am now going to export my models to Blender to do animations.
Jul 19, 2012 9:24 PM UTC
Hi Damian...
I totally feel your pain here and I agree. Here's a bit of advice... if you're doing anything short of full blown mechanism animations, do not use Pro/ANIMATE.
Instead, use Creo View. Hopefully you have access to at least one standard license of Creo View. You can literally make a simple animation directly from a Creo/ProE model in seconds with features sorely lacking on Pro/ANIMATE. You can select hardware and have them unscrew themselves... then fade out. You can easily animate a model from an assembled to an exploded state while spinning the model in space and cross-sectioning it, too.
Creo View is everything you'd want in Pro/ANIMATE without the indescribably frustrating hassles and problems. Anyone can download Creo View Express (ProductViewExpress) for free. I believe you'll need at least a standard license to perform animations, though.
Thanks!
-Brian
Brian K. Martin
Sr. Mechanical/Application Engineer
SGT, Inc. under contract to
NASA Goddard Space Flight Center
301.286.0059 (NASA Office)
443.421.2532 (Cell)
Jul 20, 2012 6:24 AM UTC
I just want to say that the comparison with Maya is totally unfair.
Maya (formerly Alias) started out as animation software from the start,
dating back as far back as 1998. Pro/Engineer is and has been a CAD
tool, with animations being nothing more than a nice-to-have extra. (If
you bought Pro/E to create animations, you have yourself to blame for
the inconvenience, cause then you bought the wrong software.)
Not that I don't agree that PTC often creates half-baked software
solutions, but let's judge them in a fair way 😉
How do other CAD tools like Unigraphics or Catia so in the animation
department? Does anyone know?
Blender is also a dedicated animation tool, so I think you'll be much
happier using that.
Best regards,
Patrick Asselman
Jul 20, 2012 10:32 AM UTC
I agree with Patrick. A niche player, focused on a particular function, is always (mostly) superior compared to a general tool. Of course, there is nothing wrong with comparing tools, but in the comparison, the advantage of using one general tool to tackle a wide variety of activities should be part of the comparison.
Met vriendelijke groeten,Best Regards,
Hugo.
Jul 20, 2012 12:16 PM UTC
Just my $.02,
I would agree to you up to a point, IF PTC developed their animation program from scratch.
As far as I can remember, PTC bought the animation suite by buying another company. The hope here is that they will add 'hooks' to the software to provide seamless file translation, and then integrate the software into the core suite. I think that quite a lot of the functionality beyond CAD came this way (Mechanica, Windchill, Arbortext, Toolmaker, etc...). This is different than licensing technologies (constraint managers, solid modeling engines, etc...).
On a lot of fronts, I think PTC has had a lackluster (at best) track record in this regard, animation is no different.
If I was starting again today, I would rather have a core CAD/PDM system that manages the model, assembly, drawing database extremely well, and let 3rd parties provide tightly integrated solutions to specific missing features (like CAM, CAE, animation, rendering, etc...) through an open API and something like RPC's, DDE's or similar.
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
Jul 21, 2012 12:26 PM UTC
Just my $.02 too...
Chris I agree with you also...up to a point. The core CAD/PDM solution with "tightly integrated third party add ons" was tried and it failed miserably. It was called SDRC. In fact it was that exact"promise" that SDRC touted that finally ousted PTC from being considered as Ford Motor Company's design software back in the day. That along with arrogance. But that is another story for another day.
With regard to Animation, I was once told by a PTC employee if I wanted to get animations done well...use something else. In fairness, the animation software has been left to wither on the vine for 15 years and is not in PTC's sweet spot. Too many dollars and effort creating WindKill to address the lacking modules and functionality.
Jul 25, 2012 5:34 PM UTC
Hi all,
Two silly questions from a long time ProE user, novice CAD admin (we lost ours a while back).
I need to install a new license file that will allow us to test run WF5 while allowing us to continue using WF2 with 3.3 (unfortunately our current Production environment). We're hoping to move to Creo 2 before the end of the year.
1. If I don't know where the current license file exists (our configuration was originally set up so that Pro's launched from a load point), is there a way to find out? A file that has a path, something like that?
2. I was hoping to get a new license file that would allow us to keep our current WF2/3.3 configuration and give us the ability to test drive Creo 2, but was told by PTC that the license doesn't go back that far. Makes sense. Does anyone know if I can have a separate license file on a separate machine in order to run Creo 2?
Stefan
Jul 26, 2012 9:24 PM UTC
Hi Stefan,
1) Do you know which server your license management software is located?
There should be some tools, (LMTOOLS) for example, that will have a file
path to the license files. If you don't know which server it is located on,
this can be found on ptc.com/support.
2) To clarify, are you asking if having a Creo 2 license on a separate
licensing server from your WF 2 license will cause any issues? I do not
believe so. The two should not interact. I ran into a similiar issue with
WF5 and 2000i where we could not have both licenses in the same file nor
could we have them on the same machine.
Please let me know if you have any other questions.
Zack
Zachary D. Alexander
Operations Manager - RAPiDS
ProductSpace Solutions Inc.
Phone: 630-495-2999 Ex. 8104
Cell: 630-460-4905
On Wed, Jul 25, 2012 at 12:34 PM, Mueller, Stefan <
-> wrote:
> Hi all,
> ours a while back).
> the year.
> that?
> Thanks,
> Stefan
