3-Newcomer
Simple Cable Routing in CREO 8 using axis to axis for from/to
Using CREO 6, it was easy to route a cable by selecting an axis for "from" and the ending axis as "to" after selecting "Allow Location" under "Options."  However, as new user to CREO 8, I am unable to select any axes and have to use a coordinate system instead--usually not as convenient.  Is there a way to use an axis for routing in CREO 8?
Gaby_KAnswer
did you try to RMB -> add location on the required axis (during the routing)?
Gaby_K12-AmethystAnswer
3-Newcomer
Thanks for your response.  Not sure what "RMB" means?  In CREO 6, any axis during initial routing was selectable, however, in CREO 8, using the same approach, unable to select an axis, on CSYSs.
Right Mouse Button click
