Simple representation material change?
Hi All,
Is it possible to assign two materials to a part and switch between them with simple representations? I have a concept for which I would like both extruded and cast quotations in different materials; I have simple reps that switch between draft features etc, but being able to switch material would be very useful.
Many thanks.
acoates1-VisitorAuthor
Nudge...any suggestions, please?
Yes you can..
In your family table, add a new table column.
Select "Parameter" and then select the PTC_MATERIAL_NAME parameter.
Now, type the desired material name for each instance in your fam. table.
(all materials must be defined as "Materials in Model")
Assign both materials to the part. Then in relations add
PTC_MATERIAL_NAME = "MATERIAL_1"
IF PARAM == VALUE
  PTC_MATERIAL_NAME = "MATERIAL_2"
ENDIF
Great stuff, thanks All. I'd prefer to avoid family tables if I can, so Dan: does"value" in your expression above need to be changed to anything? I'm not sure what it relates to.
You could have a parameter  of CAST set to YES/NO parameter
IF CAST == YES
ENDIF
Thanks Dan. So could I switch between this parameter in a simple rep or would it need a family table again?
Andy
Just by curiosity, any particular reasons why you are avoiding family tables?
I find family tables one of the most powerfull features in Creo
Indeed, they have their uses, but unfortunately the are (we have found) incredibly sensitive to how they are handled in and out of Windchill which has burnt us before and leaves us with a couple of legacy issues to this day!
2-Explorer
June 4, 2015
What issues?
