Simplified Rep
Hi All,
I'm using WF3 and product view lite.
I have some model were the simplified rep are shown in product view in the model column.
I've recently tried to export newer model and I can't see any simplified rep.
I must forgot to tick a box somewhere.
Any help would be appreciated.
Nicolas
Not sure about WF3 and productview lite but have the same problem in Creo to Creoview not showing simplified reps. Tried editing receipt file and adding config.pro options for export but by default it already included simplified reps so it should work. Exported from Master rep of course. I wonder if PTC is playing games with which version of Creoview they are giving this capability to. Perhaps we need more $$$ for MCAD Creoview to view simplified reps in Creoview now???
Let me know if you figured it out and Ill do the same.
Thanks!
Gil
Gil,
Can you attach a screensheet of the simplified rep View manager in Creo showing the model tree structure and how you are applying conditions to each lower level object? There are limitations for the publisher that you may not be aware of.
There are simplified reps of the lower levels that are subsituted within the upper level simplified reps. Is there documentation somewhere that would discribe these limitations and if there is a work around? Note I dont have access to the knowlegde base so links to that won't work for me.
