Skeleton parameters and Copy Geoms
Good morning,
Skeletons are great for Top Down design, and are generally used to create
geometry references on which to hang components and/or which can be passed
into parts or sub-assemblies via Copy Geoms. What method are folks using to
copy skeleton parameter values into lower level sub-assemblies and/or parts?
We'll be using some Pro/Program, but you can't Execute parameter values from
a part (skeleton or otherwise) to another part. Plus, we'll likely have a
Family Table at the part level and you can't Execute parameter values into
multiple instances of the same Family Table...
Thanks in advance,
Gavin B. Rumble, PE
Solid Engineering
336-224-2312
Thanks in advance,
Gavin B. Rumble, PE
Solid Engineering
336-224-2312
