3-Newcomer
Sketch
Hi, in feature modeling, section sketch, double clicking on a dimension to modify its value doesn't work any more.
This happens since I installed Creo Parametric 9.0.3. on Windows.
Thank you for your help.
Giovanni
Chris3
Have you tried this on another machine? Have you tried just restarting Creo? Can you share the file? If not then I would suggest opening up a ticket with PTC.
