8-Gravel
Sketcher "Point on Extension Line" Constraint
During sketching I often run into this constraint and I would like to disable it, the problem is, this one is not in the list of constraints in the options menu. A google search has not been fruitful.
I do not want the points of a box I am sketching to snap onto other references, I know I can right click to disable it but would prefer to not have to deal with this constraint at all.
Any tips would be appreciated.
kdirth
kdirthAnswer
Holding shift disables creation of all constraints not locked.  💡
kdirth
kdirth21-Topaz IAnswer
M.Shuler8-GravelAuthor
8-Gravel
This will work for sure.
If there is no way to completely disable this constraint I will mark this as the solution, but it's more of a workaround IMHO.
kdirth
Try config sketcher_point_on_entity_constr no.
