Some parameters of a hole feature are no longer accessible in PTC Creo 9.0.3.0
Hi all,
I'm trying to make a custom note for the MBD annotation of a tapped hole pattern.
The note contains the following text
4X &SCREW_SIZE:FID_374 &THREAD_SERIES:FID_374 - &CLASS:FID_374 &Thread_Length:FID_374
where FID_374 is indicating the hole with feature id 374.
It is my intention to replace 4X with something like &HOLE_INSTANCE_COUNT.
My problem is that the parameters THREAD_LENGTH and THREAD_DEPTH no longer seem to be available in PTC Creo 9.0.3.0 (although they are mentioned in the manuals).
The hole pattern feature has apparently no parameters. So how do I access the parameter &HOLE_INSTANCE_COUNT?
If I take a look at the original note
&METRIC_SIZE &THREAD_SERIES - &THREAD_CLASS &STD_HOLE_TYPE &VAR&_THREAD &THREAD_DEPTH
&NUMBER_SIZE DRILL ( &DIAMETER ) &VAR_DEPTH &DRILL_DEPTH &HOLE_INSTANCE_SPACE&HOLE_INSTANCE_HYPHEN_SYMBOL&HOLE_INSTANCE_LEFT_BRACKET&HOLE_INSTANCE_SPACE&HOLE_INSTANCE_COUNT&HOLE_INSTANCE_SPACE&HOLE_INSTANCE_RIGHT_BRACKET&HOLE_INSTANCE_SPACE&HOLE_INSTANCE_LABEL
Where do these parameters then come from?
JB_87049Answer
I found the answer to my question in this video
https://www.youtube.com/watch?v=HpzO3HqrbO4
JB_8704915-MoonstoneAuthor
After doing some further tests, it seems that &THREAD_DEPTH and &THREAD_LENGTH are only available when a blind depth value is entered. If the option through thread is chosen then the parameters disappear from the list.
JB_8704915-MoonstoneAuthorAnswer
This support page also gives some info
