Jun 27, 2022 5:55 PM UTC
Can you please check BOM table simplified representation.
Path is -->  select repeat region --> select model /rep --> select your BOM table --> select your assembly part number --> select master rep
then check it.
Definitely, it will solve your question.
From that, if you want to show your simplified representation/required BOM in the drawing table. approach in that way.
Balachandran M
chandrumx6@gmail.com
StephenW
Apr 27, 2022 5:36 PM UTC
What parameters or values is your bom table using? If the table is using the parameters the parts/assy's don't have, they won't show up.
If your table has filters or relations, it could cause parts/assembly's to not show.
If you have sub-assy's and you want the parts in the sub-assy to show, you have to set the item or table to recursive.
There are potentially a lot of reasons.
Apr 28, 2022 11:41 AM UTC
@SJ_9672882 wrote:
Hi, i am having problem with displaying my part in BOM table. I can only see parts or assemblies, that are downloaded from FESTO website. Can anybody please help me? thank you :))
in Drawing mode save repeat region table as .tbl file and upload it. This enables us to see repeat region definition.
If it is possible, you can zip drawing + assembly + part files into zip file and upload this zip file.
then check it.
Balachandran M
