Source of ptc_materlal_name
Why Source of PTC_MATERIAL_NAME is User-Defined?
is not User Defined
Patriot_1776
Huh???  It IS "user-defined", YOU pick the material from the library.  🙄
PHABIO1-VisitorAuthor
Yes but i don't have create it.
I can't create a parameter called PTC_MATERIAL_NAME and if want delete all parater fitred by source:User-Definition i cant delete PTC_MATERIAL_NAME because i cant remove the relation whit the material.
Yes i pick in the material so i SET the parameter but i dont CREATE it so im not a Source.
i have modified My filter
         Source = User-Definied
         and
         access = Full
         and
         name != PTC_MATERIAL_NAME
and it work but is'nt nice to added del last row
         and
         access = Full
         and
you have to ask PTC Support to get requested answer. Community users do not know how PTC implemented PTC_MATERIAL_NAME parameter ...
