space letters .500 tall
  • May 1, 2017
  • 2 replies
  • 1193 views
adding draft on the letters and like to space them apart and letter are .500 tall ,
StephenW
I don't think there is any "spacing" option to control the text in a sketch other than aspect ratio, but that stretches the letters too.
You may have to do individual letters.
bcockrell1-VisitorAuthor
I was using the text box do letters  ( front3d ), but I see I can not space the letters out in difference space dimension. like if the letters is .050 .
I use the letters  text box  ,per letter . then I adding draft to the letters each letter.
I there way  I can take each letter with the draft  (extrude ) and make a library . then just pull them on my model ?
after put the letters and number on the model with the right space that look good  . then I can print the part on a 3d printer.
thank for the help
