Spools in BOMs on drawing?
Is there a way to display the spool information in the BOM? I've already set-up relations that my quantities are displayed as strings, so it would be easy to get their lengths to also display. I just need to fidure out how to get the spools themselves to show.
When I click Repeat Region > Attributes > and turn on cabling information, several blank lines are injected into my BOM. I don't know what these are, as they're are 13 of them when I have 30 wires and 2 spools.
Oh, I should probably note that the company I work for has the Cabling package, but not the schematic - so I am working in a standard drawing.
Any help would be much appreciated!
Hi Mikulka,
To get spool info in BOM, you need to add one repeat region row and give parameter &harn.spool.name in part number column. and give &harn.spool.len[.0] in Quantity column...then select repeat region>model/Rep> select your harness part.
...Ram
