Standard Parts for Assembly
Hi all
Is there any method in CROE assembly to insert standard parts e.g bearings,bushings etc to to an assembly where it is needed accordingly.
for example in Solid works you just insert bearing from library and select a shaft surface,bearing will automatically adjust its dia to it whatever the library bearing internal dia is.Hope i make the question clear.
