Start part
I created a start part and a drawing for it.
When I start a new part and select the above created start part as template and pick “copy associated drawing” brings the drawing but not format. I have to update the format or keep the format in my current workspace before I start working on new part file.
Is there a way you can get a drawing file along with its format?
Thanks in advance.
Sharath
snellutla1-VisitorAuthor
For more clarification. I already assigned start part, format locations in my config file.
If I create a drawing by selecting drawing template it will bring the template along with it.
Issue is If I am creating a new part file by selecting a "start part" and pick option "
Sharath
The things that I would check:
* Start part and drawing are in the same folder with identical
names.
* All appropriate config options are set.
* There are not extra config files loading that may be overriding
your set options.
Beyond that, I dunno.
Doug Schaefer
Doug,
Thanks for the response.
I will try to make it work somehow if pro-e has the ability to bring the drawing along with it's format if I pick start part (*.prt) and select copy associated drawing.
So
is it possible?
did any one successfull in achieving this feat?
Sharath
