static stresses analysis on welded assembly can it be done?
Hi
1. On general, can static stress analysis can be done on assembly ?
2. i have a sheet metal assembly made of 2 (8mm thick) sheet metal parts, ther are assembeled by grooves and welding
i have added a welding by using the "application" featur assuming that this way i could do a static stress analysis on assembeld parts, but i dont know if CREO conceder it as an actually welded parts as in real and do the correct sterss analysis
- Is this a way to do it?
- regardless the last question, what is the best methode to do a static stress analysis to a welded assembly or any other assembly that used by screws (i most mean to welding, since screws and oter mechanical connecting fasteners can be simulated) ?
thx
Shay
