3-Newcomer
STEP file imported model tree
When a step file is imported Creo creates a duplicate on the model tree. why does that happen and is there a way to get rid of the unnecessary top level?
How are you bringing the file into Creo?
Creo can open a Solid Works file directly, just change the file selection type and open the file.
Import will bring the Solid Works file into an existing file, thus the part in a part.
3-Newcomer
The file was created in creo and saved as a step file to have a smaller size file. but when imported back it creates the assembly within an assembly.
I guess this is "standard" behavior which cannot be changed.
