Sep 8, 2017 7:50 AM UTC
STEP Turn into surface. Double sided edge fix
I have file from client that creo imports as surface. With IDD I found out there are a few edges that gives "Bad two-sided edge" it also gives a solution, that says use the"Merge Crv/Wfm". Where could I find this tool?
Sep 8, 2017 11:58 AM UTC
in Creo Parametric 2.0 M070 I did following actions:
1.] When I opened captofix.stp, I set using External accuracy
2.] I edited definition of import feature and went to IDD mode using following button
3.] I clicked Repair button and set Reair Tangency option
4.] Finish Repair action using green check button
5.] Close IDD mode using green check button
6.] Click Solid import button and green check button to finish Edit Definition
7.] Solid model is available
atilas11-VisitorAuthor
Sep 8, 2017 12:24 PM UTC
Hello Martin,
Thanks for informative reply, however, that was first thing that I did and most of the time it worked for me as well. However for this model it doesn't. When I go into geometry check it shows for me a few problems that repair doesn't fix. I usualy ignore Bad vertices, it seems creo handles them well. However other two types of problems I don't know how to resolve.
Sep 8, 2017 12:29 PM UTC
unfortunatelly I do not know how to deal with IDD geomchecks.
Do you use commercial -OR- education license ?
What Creo version do you use ? I can test model repair in it and send you the resulting model.
