STOCK SIZE PARAMETER IN MODEL?
Creo 7
This seems insane that its not easier than this.
I can not figure out how to get my parameter in my model to display my full stock size?
I have the following parameters: thickness / width / length
Then I have a relation: thickness=d12, width=d9, length=d10 (and these default to 2 decimal places)
So then I thought, the relation, (stock_size = thickness "x" width "x" length) would give me what I'm after.
Ex 1.50 x 2.50 x 3.50
Nope, further digging got me to the following equation:
STOCK_SIZE = itos(D12) + "." + itos( (D12 - floor(D12)) * 100 ) + " X " + itos(d9) + "." + itos( (d9- floor(d9)) * 100 ) + " X " + itos(d10) + "." + itos( (d10- floor(d10)) * 100 )
Which I arrived at because I needed this specific "itos" function to give me 2 decimal places. Now I get 2.50 x 3.50 x 4.50? (Not the 1.50 x 2.50 x 3.50 that it should be)
So all my values have increased by (1) somehow.
The itos function makes no sense to me but I suppose it works if I can find out what is causing it to increase all my values by (1)?
KenFarley
KenFarleyAnswer
Here's a previous discussion that deals with this topic. The answer I gave is a bit more complicated, preventing weird results and taking into account all the possiblities of dimensional values.
https://community.ptc.com/t5/3D-Part-Assembly-Design/How-to-make-text-with-dimensions/m-p/492558
Lol, it's been a while since this classic issue showed up on the forum.
I am not sure, but your formulas for deriving the string representation of a number seem different from what I am used to.
This thread is my go-to for the hack needed:
Converting Real Numbers to Strings
KenFarley
The ITOS function will round numbers before giving you the results. So ITOS ( 1.50 ) = "2".
You need to use the floor function when generating the integer portion of your number i.e. ITOS ( floor ( D12 ) ).
Another danger of the ITOS function that has annoyed me for years is that ITOS ( 0 ) = "", or that a zero value doesn't yield the zero character, but an empty string.
KenFarley
KenFarley21-Topaz IIAnswer
MORECREO14-AlexandriteAuthor
That seems like an insane way to get there. Very "Creo" like lol. However, that worked great. Thank you!
StephenW
https://community.ptc.com/t5/Creo-Parametric-Ideas/RTOS-function-in-relations/idi-p/469120
Please vote on the product enhancement request from 2014...you know it's way older but this is the one with the most votes and isn't archived.
KenFarley
Wow, I'd never seen that idea.
The coding for such a function would be pretty simple. It's the kind of problem one gets for a beginner level programming class.
