Stop switching Working Directory when saving a Backup
Hello everyone
Is there a way to tell Creo to stop messing around with the Working Directory when saving something as a Backup?
That Creo switches the Working Directory in general is the smaller problem, the big issue is that it changes the File-location of the components that are in session, so you have to erase the entire session or you might mess up your assembly. (Where is the logic? If I save a backup I want to have a backup and not a new Working Directory!)
I know the issue has been around for quite a while, but I only found people complaining about it, and no one who had a solution.
(Maybe I'm just blind)
Regards Daniel
@Daniel_319988 wrote:
Hello everyone
Regards Daniel
it does not make any sense to discuss backup command behavior. According to PTC terminology, it works as expected.
18-Opal
The “as expected” is most interesting part behind the original question.
Dave
