Sep 19, 2022 4:27 PM UTC
Style of lines changes after printing as pdf
My central axes looks like this in Creo:
And that is also how i want it to look like.
But when i print it as a pdf file it looks like this in the pdf version:
Same goes for cosmetic thread lines:
No idea why that changed but is there an option to change it?
Greetings
Spedex
Sep 20, 2022 6:03 PM UTC
@Spedex wrote:
In the attachment you find now a file.zp file with the table and the config file.
I do not use the Save As Button, I use the Print option.
Edit: If I use the Save As option, the central axes actually looks like how it should look like, but every other line does not...
I uploaded corrected files.
Please try Save a Copy command, too.
Sep 19, 2022 4:33 PM UTC
Greetings
Spedex
please next time upload your pentable and Creo data for testing purposes.
I guess axes are drawn by a pen whose definition contains a pattern specification. pattern specification overrides line font.
Spedex12-AmethystAuthor
Sep 19, 2022 6:30 PM UTC
Hello, i think my pentable is the following:
pdf_use_pentable yes
use_8_plotter_pens yes
pen_table_file path_to_file
pen table file - example
pen 1 thickness 0.015 cm; color 0.0 0.0 0.0; drawing_color
pen 2 thickness 0.01 cm; color 0.0 0.0 0.0; letter_color, datum_color
pen 3 pattern 0.5, 0.2 cm; thickness 0.03 cm; color 0.0 0.0 0.0; half_tone_color
pen 4 thickness 0.035 cm; color 0.0 0.0 0.0; edge_highlite_color
pen 7 thickness 0.015 cm; color 0.0 0.0 0.0; dimmed_col
i know that pen 2 changes the thickness of the central axes lines, but not sure where there should be any pattern...
Sep 20, 2022 7:16 AM UTC
please provide more details. Use similar procedure as below.
I created testing data in Creo Parametric 4.0 M140. See attachment cyl.zip.
My config.pro contains following lines:
pen_table_file E:\users\creo4_parametric\pentable.pnt
pdf_use_pentable YES
cyl.zip contains Creo prt+drw, pentable file and PDF file generated using Save As command.
Axis and hatching is displayed correctly in PDF file.
