SUMMARY 2 "Is it possible to show datum curve in one particular view only?"
Pro Gurus:
Everything works fine after putting a check mark to "Ignore display status
of layers in the model" and "Change display of model layers with same name
in drawing only..." box. These feature can be access in drawing mode, #
Settings tab, # Drawing Layer status.
Thank you all for your valuable help and time.
Frank
Frank
