summary: Drawing won't pull up until Assembly is running.
Thanks to everyone who responded;
I have not had an opportunity to run down all the suggestions but I have a sneaking suspicion that Windchill issues may be the main culprit.
I did leave out some info last time about the workstations...
WF4 M092
Windchill 9.0 M030
Win XP 64 SP2
Xeon based with at least 8 GB ram.
NVIDIA FX3700
Summary so far...
Are you attempting to open the drawing from Windchill? I know that if you select the Open in Pro/ENGINEER icon, even the smallest of drawings take a ridiculously long time to open. This is regardless of whether or not the file is in your workspace. I always type in the filename in the open file dialog box. This probably isn't the issue, but if it is, it's an easy fix. I think when you select the Open in Pro/E icon, there's a java thing going on between the PLM system and Pro/E. Just my thoughts.
Jeff
WF4 M092
Windchill 9.0 M030
Win XP 64 SP2
NVIDIA FX3700
Summary so far...
Jeff
