Mar 8, 2011 4:18 PM UTC
Summary: Is it possible to create a swept blend with two trajectories, one straight and one curve?
- 3 replies
- 1484 views
- Translate All
Pro Gurus:
Thank you all for your suggestion and help.
Apparently Var Sec Sweep and Boundary sweep are the tool needed to achieve
this. However, I am still unable to get the shape correctly using Var Sec
Sweep. I am not sure what I am missing here.
I will try Boundary Sweep.
Attach is the Pro/E file, in case someone have time to check it out.
Frank.
> *From:* Frank Giovani [
Frank.
