Aug 10, 2022 2:06 PM UTC
Support of Adopt OpenJDK11
I am using Creo Parametric - Release 6.0 (connected) Release 6.0 and Datecode6.0.3.0
We have been using Creo4.0 M120 and Creo6.0.3.0. We would like to know if Adopt Open JDK 11 is compatible with both the Creo versions.
Here are the errors that I faced
Aug 10, 2022 2:25 PM UTC
You need to know if if AdoptOpenJDK is compatible with Creo. When searching the knowledge base you will find this reference article : https://www.ptc.com/en/support/article/cs296661
In a nutshell the support of such equivalent to Oracle JDK is under consideration with no commitment at the moment.
To speed things up, filing a Product Idea is the better route.
Have you considered Amazon Coretto though?
Sarim4-ParticipantAuthor
Aug 16, 2022 7:39 AM UTC
Hi Remy,
Am still not clear with any of the Openjdk's.
No, I did not consider Amazon Coretto.
Aug 16, 2022 10:24 AM UTC
You are confused with Openjdk and did not consider Amazon Coretto.
You initially requested whether openjdk is compatible with Creo and the answer is that it is unsupported.
Is there something additional that i can do to help you?
