Suppress/Unsuppress part in assembly through Pro/Program
I'm trying to create a program where I suppress a part and unsuppress another which should act as a replacement depending on what input I choose but don't know how to solve the errors.
Here's my code:
VERSION 5.0
REVNUM 8237
LISTING FOR ASSEMBLY UPPGIFT2B
INPUT
LEVER_TYPE STRING
"Choose lever"
END INPUT
RELATIONS
IF LEVER_TYPE == "1"
ADD PART BYGEL
!*** ERR: no END RELATION statement for RELATION on line 0
INTERNAL COMPONENT ID 89
PARENTS = 54(#9)
END ADD
!*** ERR: unmatched END statement encountered
ADD SUPPRESSED PART BYGEL_ALT
INTERNAL COMPONENT ID 206
PARENTS = 54(#9)
END ADD
IF LEVER_TYPE == "2"
PARENTS = 54(#9)
ADD PART BYGEL_ALT
!*** ERR: no END ADD statement for ADD on line 0
PARENTS = 54(#9)
END ADD
END RELATIONS
ADD FEATURE (initial number 1)
INTERNAL FEATURE ID 1
DATUM PLANE
NO. ELEMENT NAME INFO
1 Feature Name Defined
2 Constraints Defined
2.1 Constraint #1 Defined
2.1.1 Constr Type X Axis
3 Flip Datum Dir Defined
4 Fit Defined
4.1 Fit Type Default
NAME = ASM_RIGHT
FEATURE IS IN LAYER(S) :
01__ASM_ALL_DTM_PLN - OPERATION = SHOWN
01__ASM_DEF_DTM_PLN - OPERATION = SHOWN
END ADD
ADD FEATURE (initial number 2)
INTERNAL FEATURE ID 3
DATUM PLANE
2.1.1 Constr Type Y Axis
4 Fit Defined
NAME = ASM_TOP
END ADD
ADD FEATURE (initial number 3)
INTERNAL FEATURE ID 5
DATUM PLANE
2.1.1 Constr Type Z Axis
4 Fit Defined
NAME = ASM_FRONT
END ADD
ADD FEATURE (initial number 4)
INTERNAL FEATURE ID 7
COORDINATE SYSTEM
2 Name Display Option YES
3 Display Zoom Dependent Option NO
NAME = ASM_DEF_CSYS
05__ASM_ALL_DTM_CSYS - OPERATION = SHOWN
05__ASM_DEF_DTM_CSYS - OPERATION = SHOWN
END ADD
ADD PART BOTTENPLATTA
INTERNAL COMPONENT ID 42
END ADD
ADD PART DYNPLATTA
INTERNAL COMPONENT ID 43
PARENTS = 42(#5)
END ADD
ADD PART HÅLLARE
INTERNAL COMPONENT ID 51
PARENTS = 43(#6)
END ADD
ADD PART HÅLLARE
INTERNAL COMPONENT ID 52
PARENTS = 43(#6)
END ADD
ADD PART KUGGAXEL
INTERNAL COMPONENT ID 54
PARENTS = 52(#8)
END ADD
ADD PART INSEXSKRUV
INTERNAL COMPONENT ID 58
PARENTS = 43(#6)
END ADD
ADD PART INSEXSKRUV
INTERNAL COMPONENT ID 61
END ADD
ADD PART SPARSKRUV
INTERNAL COMPONENT ID 63
PARENTS = 42(#5) 43(#6)
END ADD
ADD PART STYRSTIFT
INTERNAL COMPONENT ID 83
PARENTS = 43(#6) 52(#8)
END ADD
ADD PART STYRSTIFT
INTERNAL COMPONENT ID 86
PARENTS = 52(#8)
END ADD
ADD PART STYRSTIFT
INTERNAL COMPONENT ID 87
END ADD
ADD PART STYRSTIFT
INTERNAL COMPONENT ID 88
PARENTS = 51(#7)
END ADD
PARENTS = 54(#9)
END ADD
ADD PART DISTANS
INTERNAL COMPONENT ID 90
PARENTS = 42(#5)
END ADD
ADD PART DISTANS
INTERNAL COMPONENT ID 93
END ADD
ADD PART DISTANS
INTERNAL COMPONENT ID 94
END ADD
ADD PART DISTANS
INTERNAL COMPONENT ID 95
END ADD
ADD PART STANS
INTERNAL COMPONENT ID 97
PARENTS = 52(#8)
END ADD
ADD PART STANS
INTERNAL COMPONENT ID 105
PARENTS = 52(#8) 97(#21)
END ADD
ADD PART STANS
INTERNAL COMPONENT ID 117
PARENTS = 51(#7) 97(#21)
END ADD
ADD PART STANS
INTERNAL COMPONENT ID 120
END ADD
ADD PART STOPPAXEL
INTERNAL COMPONENT ID 123
PARENTS = 51(#7) 42(#5)
END ADD
ADD PART LINJAL
INTERNAL COMPONENT ID 129
PARENTS = 42(#5)
END ADD
ADD PART TÄCKPLATTA
INTERNAL COMPONENT ID 132
PARENTS = 42(#5)
END ADD
ADD PART SPARSKRUV
INTERNAL COMPONENT ID 183
END ADD
ADD PART SPARSKRUV
INTERNAL COMPONENT ID 184
END ADD
ADD PART SPARSKRUV
INTERNAL COMPONENT ID 185
END ADD
ADD PART SPARSKRUV
INTERNAL COMPONENT ID 186
END ADD
ADD PART SPARSKRUV
INTERNAL COMPONENT ID 187
END ADD
ADD FEATURE (initial number 33)
INTERNAL FEATURE ID 201
FEATURE WAS CREATED IN ASSEMBLY UPPGIFT2B
PARENTS = 42(#5)
DATUM PLANE
2.1.1 Constr Type Offset
2.1.2 Constr References Defined
2.1.3 Constr Ref Offset Value = -26.0000
4 Fit Defined
NAME = ADTM1
FEATURE'S DIMENSIONS:
d56 = (Displayed:) 26
( Stored:) -26.0 ( 0.01, -0.01 )
END ADD
ADD FEATURE (initial number 34)
INTERNAL FEATURE ID 203
PARENTS = 42(#5)
DATUM PLANE
2.1.3 Constr Ref Offset Value = -91.0000
4 Fit Defined
NAME = ADTM2
d57 = (Displayed:) 91
( Stored:) -91.0 ( 0.01, -0.01 )
END ADD
ADD PART FJADER
INTERNAL COMPONENT ID 192
END ADD
ADD PART KULA
INTERNAL COMPONENT ID 197
PARENTS = 42(#5) 192(#35) 129(#26)
END ADD
MASSPROP
END MASSPROP
!*** ERR: file contains more IF's than ENDIF's
One possible solution follows
INPUT
BYGEL_OR_BYGEL_ALT STRING
"Which lever to use? B(bent) or S(straight)? "
END INPUT
IF BYGEL_OR_BYGEL_ALT == "B"
ADD PART BYGEL
PARENTS = 54(#9)
END ADD
END IF
IF BYGEL_OR_BYGEL_ALT == "S"
ADD PART BYGEL_ALT
PARENTS = 54(#9)
END ADD
END IF
ENDIF line is missing in your program.
Example:
If you want to suppress BYGEL component, then you have to add two blue lines.
ADD PART BYGEL
PARENTS = 54(#9)
END ADD
ENDIF
I have now added the two blue lines but still get some errors:
VERSION 5.0
REVNUM 8237
INPUT
LEVER_TYPE STRING (1 or 2)
"Choose lever"
END INPUT
RELATIONS
ADD PART BYGEL
PARENTS = 54(#9)
END ADD
PARENTS = 54(#9)
END ADD
ENDIF
END RELATIONS
TomU
You need a space between "END" and "IF" in Pro/Program.  Use "END IF"
